Технология No-Till без рекламы. Плюсы и минусы.
19817 сообщений
: кузбасс
22.12.2012 - 18:43
: 147
Don Emilio пишет:
интересно а есть такие же, но с культиваторной лапой вместо анкера
Жалоба
Посмотри Агрокараван в омске
: Симферополь
19.04.2016 - 11:33
: 3229
fgrubin пишет:
Здесь вот исследование по долгосрочному но-тиллу 47-49 лет [изображение] в сравнении с мини-тилл и вспашкой и в сравнении с нетронутым лесным участком почвы!
Long-Term No-Till Impacts on Organic Carbon and Properties of Two Contrasting Soils and Corn Yields in Ohio
Краткие выводы:
Tillage infl uence on soil properties and crop productivity depends on soil, crop, climate, and duration. Two long-term experimental sites with contrasting soils were selected to assess the infl uence of no-till (NT), minimum tillage (MT), and plow tillage (PT) under continuous corn (Zea mays L.) and corn– soybean [Glycine max (L.) Merr.] (CS) rotations on soil organic C (SOC) stock, bulk density (ρb), water-stable aggregation (WSA), aggregate tensile strength, penetration resistance, available water capacity (AWC), and corn yield. Experiments began in 1962 in northeast Ohio on a well-drained silt loam soil and in 1964 in northwest Ohio on a poorly drained clay loam soil. Results were compared with soil under an adjacent undisturbed woodlot (WL). The WL soils had the highest SOC content and stock. In the cultivated silt loam soil, stock was higher under NT (20.7 Mg ha−1) followed by MT (17.3 Mg ha−1) and PT (16.8 Mg ha−1) for the 0- to 10-cm depth. Soil ρb for this depth was lower under NT by 8 and 3% than PT and MT, respectively. The percentage of total WSA >2000 μm in soil under NT (47%) was signifi cantly higher than under MT (38%) or PT (34%). A similar trend was observed for the clay loam soil. Rotation also infl uenced soil properties. Corn yields were higher (3 yr) and lower (1 yr) during 5 yr for the silt loam soil under PT than NT and unaffected or slightly higher under NT for the clay loam soil. Long-term (47–49 yr) use of NT practices are highly sustainable and result in higher SOC and WSA, lower ρb, and greater AWC content than MT or PT.
перевод от гугла:
Влияние обработки почвы на свойства почвы и урожайность зависит от почвы, урожая, климата и продолжительности. Два долгосрочных экспериментальных участка с контрастными почвами были отобраны для оценки влияния необрабатывающей (NT), минимальной обработки (MT) и вспашки (PT) под сплошной кукурузой (Zea mays L.) и кукурузно-соевой [ Glycine max (L.) Merr.] (CS) повороты на почве органического C (SOC) запас, насыпная плотность (ρb), водостойкая агрегация (WSA), прочность на разрыв агрегата, сопротивление проникновению, доступная емкость воды (AWC), и урожай кукурузы. Эксперименты начались в 1962 году на северо-востоке Огайо на хорошо дренированной илово-суглинистой почве и в 1964 году на северо-западе Огайо на слабо дренированной глинисто-суглинистой почве. Результаты сравнивались с почвой под соседним нетронутым лесным участком (WL). Почвы WL имели самое высокое содержание SOC и запас. В культивируемой илово-суглинистой почве запас был выше в условиях NT (20,7 мг / га), а затем MT (17,3 мг / га) и PT (16,8 мг / га) для глубины от 0 до 10 см. Почва ρb для этой глубины была ниже при NT на 8 и 3%, чем при PT и MT, соответственно. Процент общего WSA> 2000 мкм в почве под NT (47%) был значительно выше, чем под MT (38%) или PT (34%). Аналогичная тенденция наблюдалась для глинисто-суглинистой почвы. Вращение также влияло на свойства почвы. Урожайность кукурузы была выше (3 года) и ниже (1 год) в течение 5 лет для почвы суглинистого суглинка под ПТ, чем NT, и незатронутой или немного выше под NT для почвы суглинистого суглинка. Долгосрочное (47–49 лет) использование практик NT является весьма устойчивым и приводит к более высоким значениям SOC и WSA, более низкому значению ρb и большему содержанию AWC, чем MT или PT.
прямой посев это революция в земледелии !!!
: Ростовская
27.12.2016 - 11:51
: 2658
Don Emilio пишет:
давно не было твоих взрывных лозунгов)))
Это сообщение будет удалено автоматически 27-01-2019 в 10:55:00
: Ростовская
27.12.2016 - 11:51
: 2658
Александр Фаерман пишет:
Это такая же технология как и класика и минемалка. В чем заключается революция. dntknw
: Симферополь
19.04.2016 - 11:33
: 3229
тукано пишет:
Это такая же технология как и класика и минемалка. В чем заключается революция. [изображение]
Факты сверху описал господин Александр
: Полтавская область
28.02.2011 - 11:28
: 15952
Та цитата, всего лишь предисловие к публикации, а в самом тексте все более подробно изложено.
: Алтайский край
16.04.2011 - 07:55
: 3829
Заплатите за кефир, Шура!
: Ростовская
27.12.2016 - 11:51
: 2658
spirit71 пишет:
Чет видео недоступно.
: Алтайский край
16.04.2011 - 07:55
: 3829
тукано пишет:
Мосфильм от фермер.ру откат хочет, тыч смотреть на ютюб... больше ни как.
: Ростовская
27.12.2016 - 11:51
: 2658
spirit71 пишет:
тукано пишет:
Ясно. hi
україна
: Винница
31.07.2011 - 23:41
: 206
Моё видео о ноутиле на ютубе https://youtu.be/rJpGD4AZWy4 правда на украинком языке.
: Симферополь
19.04.2016 - 11:33
: 3229
агро пишет:
учили школу !!!!!
: Липецкая область
15.02.2009 - 12:28
: 5032
Всю голову сломал чего делать, какую систему удобрения выбрать под кукурузу, условия - прямой посев по подсолнечнику, почва закрыта пожнивными более менее хорошо. Вот дилема либо дать рядом с рядком 100 аммофоса и килограмм 300 селитры разбросать по мёрзло-талой, либо не морочиться и дать рядом с рядком карбамид 200-250-300 кг(может с ингибитором разложения чтоб меньше на всходы влиял), сошник удобрения 10 см от ряда стоит. Насколько фосфор принципиален для кукурузы? Мешать не вариант - смесь расслаивается.
28.02.2011 - 11:28
: 15952
Для старта не помешал бы, но это надо на линию посева. А если с боку положить за 10 см от посевного ряда, то кукуруза его возьмет только после появления вторичной корневой, т.е. стартового эффекта не получите. Будет ли он вообще работать как основное удобрения, это зависит от осадков по вегетации.
А какой у вас уровень содержания фосфора в почве? Если высокий, то экономического эффекта от фосфора с боку от посевного ряда трудно ожидать.
: Запорожская обл
26.10.2017 - 23:33
: 691
Владимир48 пишет:
Ща "Рубин" расскажет smile3 . Вы ж сами говорили главное чтобы было что дать.
: Полтавская обл.
18.03.2013 - 02:03
: 11616
Владимир48 пишет:
систему удобрения
Давай консилиум-голосовалку .
голосую за первый вариант.
: Алтайский край
16.04.2011 - 07:55
: 3829
Сайбер_01 пишет:
раскидать по мерздо-талой? А сколько от той тало-мёрзлой до всходов кукурузы? Месяц, полтора?
- Владимир?
: Алтайский край
16.04.2011 - 07:55
: 3829
учили школу !!!!!
Чо-то гуру молчите? Не иначе расчет по формулам проводите о разложение-доступности + влияние многолетнего ноутилла.. да, только на вас надёжа. Помогите все ждут, а я особенно!!! Всегда интересно почитать ваши выводы, - короткие как выстрел!!!
: Полтавская обл.
18.03.2013 - 02:03
: 11616
spirit71 пишет:
Месяц, полтора?
Может и больше.
Игорь хорошо объяснял работу нитрата,я так не смогу доходчиво.
По такому же принципу буду сеять,только селитра под бороны или культивацию.
Володя видать решил перестраховаться,по мт дать
fgrubin пишет:
Нет там первичной, вторичной.
: Алтайский край
16.04.2011 - 07:55
: 3829
Сайбер_01 пишет:
Ну я помню, в общих чертах, - типа она(селитра) растворится и будет с почвенной влагой туды-сюды плавать по горизонту, - это?
: Полтавская обл.
18.03.2013 - 02:03
: 11616
spirit71 пишет:
это
Да !
У Игоря талант педагога.
: Липецкая область
15.02.2009 - 12:28
: 5032
fgrubin пишет:
Сильно спорно, на моменте всходов корни уже сантиметров 15-20, правда ползут в основном вдоль ряда где теплая почва. Если взять полторашку водички и размыть аккуратно то это увидите.
spirit71 пишет:
Х.з. как год сложится, было и так что весны не было, снег до середины апреля потом +10 и по нарастающей и на 1 мая +25. Но в среднем где то начало апреля кормим озимку и кидаю селитру под остальное, соответственно с 25-го начало сева если почва подойдёт. Я хорошо приспособился на семечке, даю азот подкормкой по всходам под дождик, отличный результат, по таким полям почему то масличность всегда выше, засада в том что кукурузу румом не подкормить, а то бы не морочился.
Сайбер_01 пишет:
У нас всегда майско-июньская засуха, на пшенице давно уже даю основную дозу по мёрзло талой, подкормки дробные селитрой не эффективны, потому и думаю как лучше с кукурузой поступать. Карбамид рядом с рядком полную дозу в 17 году давал, но из-за не знания как правильно нужно было настроить сеялку непонятно что влияло на изреженность посева, иль токсическое действие удобрений иль неправильная настройка секций, при всём при этом росла она неплохо но волны по полям были светлые, с фосфорными удобрениями посев выровнен почти всегда.
: Геническ
30.10.2014 - 20:52
: 94
я бы кинул 300 по мерзлоталой и амофос при посеве. при посевное внесение селитры или карбамида выше 100 кг хорошо присаживает культуру при высоких дозах и большой глубине посева снижает всхожесть .
: Краснодарcкий край Новопокровский район
04.01.2009 - 13:27
: 4438
Владимир48 пишет:
в смысле!!??? мы уже скока лет кормим и на форуме пишем...а тебе ноутилл запрещает?? если дожди нормальные идут, то какие проблем? главное что бы рум не пылил и по сухому... но под дождь...
: Тамбовская область
24.11.2011 - 19:42
: 351
Владимир48 пишет:
какие были проблемы настройки, у меня ток по следу трактора когда переувлажнено было не айс?
: Липецкая область
15.02.2009 - 12:28
: 5032
68 region пишет:
Первый сезон основных косяков было два, вопервых сошник удобрения был почти в след секции, и загнал я его глубоко, сантиметров на 7-8, от этого не было полноценного семенного ложа, были пустоты в рядку, второе это слишком высокое давление на секцию и закрывающие колёса, и как следствие переуплотнение посевного ряда. В прошедшем сезоне все эти нюансы учёл и сеялка отсеяла как на картинке.
28.02.2011 - 11:28
: 15952
Сайбер_01 пишет:
Вторичной нет, первичная таки есть.
Коренева система мичкувата, сильнорозвинута, багатоярусна, має п'ять типів коріння. Зерно проростає одним зародковим корінцем. Бічні зародкові (гіпокотильні) корінці розгалужуються і разом з першим зародковим корінцем утворюють первинну (зародкову) кореневу систему. Вона особливо важлива в перші фази росту - до формування 6-8 листків.Епікотильні корені розвиваються на першому міжвузлі. Ці корені ростуть горизонтально, не розгалужуються. Роль їх у живленні рослин незначна.
Основну частину кореневої системи становить вузлове коріння, що утворюється ярусами з підземних стеблових вузлів після з'явлення на рослині 3-4 листків. Найбільшого розвитку це коріння досягає у фазі цвітіння кукурудзи. З нижніх надземних стеблових вузлів можуть розвиватися опірні, або повітряні корені. Основна маса коріння (до 60%) знаходиться в орному шарі ґрунту, окремі корені проникають у ґрунт на глибину до 3 м. Найкраще коренева система розвивається за щільності ґрунту 1,1-1,3 г/см3. Стебло кукурудзи міцне, виповнене, має до 22 міжвузлів і більше та стільки ж листків.
Надо было мне по другому сказать, что для первичной (зародошевой) корневой системы фосфор за 10 см в стороне это не уже быстрый старт.
Владимир48 пишет:
Сколько у вас дней от посева до всходов?
Чем раньше корни смогут потреблять фосфор, тем быстрее получим стартовый эффект. Стартовые удобрения должны лежать как можно ближе к семенам.
: Липецкая область
15.02.2009 - 12:28
: 5032
чез1 пишет:
Нету дождей нормальных, кукурузы в этом году 500 га, поди поймай тот дождь. Но это не главное, главное что я видел и пробовал сам, ожоги сильнейшие. А если дождь был не сильный и из пазух не вымылось хорошо то совсем печаль. Не, риск велик слишком. Надо такое что то городить под кас.
: Симферополь
19.04.2016 - 11:33
: 3229
ждем видосики от Михаила Ивановича с конференции в США !!!
: Полтавская обл.
18.03.2013 - 02:03
: 11616
fgrubin пишет:
http://agro-archive.ru/biologiya-zernovyh-kultur/1452-stroenie-kornevoy-...
На начальных этапах, развивается сначала корневая система.
